What shop do you have Jamie?
Haha birds this guy with the gear box is toying me around, u may have to bend the rules abit
Haha well we are one of the cheapiest in Australia, most are happy with our prices, but sometimes you get people telling you they can get it cheaper elsewhere or that the other joint is willing to replace more stuff for the same price...then a couple of days later they come back or get their wife to order one for them :P
Why don't you just buy a second handy like one of these? They are usually pretty good from the Jap wreckers and unopened boxes are sometimes stronger. I don't like doing anything for mates or people on here, as it almost always comes back to bite me. And yours will be the 1 in 30 reco jobs with a legit warranty issue or one of my techs will forget to put a synchro in or something lol. Business | personal.
http://www.ebay.com.au/itm/JDM-S13-S14-SR20-Transmission-Gearbox-Manual-Silvia-180SX-SR20DET-Nissan-200SX-/380410324301?pt=AU_Car_Parts_Accessories&hash=item589238e54d
http://www.ebay.com.au/itm/Nissan-SR20-Gearbox-5-Speed-S13-S14-S15-180sx-gearbox-/150759263108?pt=AU_Car_Parts_Accessories&hash=item2319f3cb84
Never ordered one when you went to the movies? Even Macca's?
Y U neva heard of Frozen coke brah?
frozen coke to me, is putting a bottle in the freezer, and that's not enjoyable at all..
i dont order crap from the movie counter, and i only order nuggets from maccas.
Just freeze coke in a plastic cup or container...and check on it regularly. When it's half way frozen, usually takes an hour and a half, take it out and mash it up / stir it. Then put it back in and check on it half an hour later...rinse and repeat until its reasonably thick. Or don't be a tight ass and go to 7-11.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
