Just go for modest power unless you plan on putting in a larger displacement engine. Any RB20 with balls = pain in the ass to drive around town and a 5000rpm powerband, although cool for motorsport, is next to useless on the road.
Guess again...I want you to do 500-1000km of normal driving on those new bearings before you go thrashing my gearbox around a track day. The last guy who did that on a freshly reconditioned box cooked the bearings and ripped every tooth off the third gear cogs = no warranty.
Lol you don't know how much I drive do u lol.
I do about a 1000km in a week and a half. Especially now that I just got another job :D
