lol I was just looking at some houses on realestate.com.au and a lot of the photos were taken with sun shining through the windows into the houses and no furniture, makes them look VERY hot to walk through, even today.
So damn cheap, someone buy it before I do something stupid:
http://www.carpoint.com.au/all-cars/private/details.aspx?R=12171585&__Qpb=1&Cr=10&__Ns=pCar_YearMade_Int32|1||pCar_RankSort_Int32|1||pCar_PriceSort_Decimal|0&keywords=&__No=15&__N=834%201216%201246%201247%201252%201282%204294966879%204294729565%204294967079%20447&SearchAction=N&silo=1011&PriceTo=447&seot=1&__Nne=15&trecs=105&__sid=1355711DA55E
Mmmm M3's.
Last night saw Aaron's friend with the convertible E46 M3 convertible. 11 inch rims on 235 tyres :/
lol just saw that it's in QLD, looks like I won't be inspecting it on a whim. Still, anyone serious about buying one, that sounds pretty legit...cleanest I've seen for a while.
Disagree re: r32 plan
Harder and harder to find a r32 which hasn't gone down the cheap thrashed path. It is better to see a clean r32 than some cheap and nasty with power because that power is nothing spectacular so it's lose-lose.
My opinion would be to restore a r32 gtr but 4dr's provide a different view
Good luck with the rebuild, in 5-10years time when everyone has moved on to their family/boring cars you will have something which wasn't discarded because of the cheap thrash mentality.
Similar example; look at all the kingswoods being restored. Everyone looking for shells including the basic 6cyl models.
Tl;dr
Also, I just love r32s.
It's like when people do up those old rotors. They're shit. But in the end it's up to the owner.
I'm doing what I had planned for my first r32, only rwd and with a sun roof :)
Hey pat... Sunroof seal is integrated into the glass.. And they don't make them anymore. FML
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
