Since I have had e85 I have had much less black on my rear bar. And your bros seems clean a lot of the time too
well i would expect that since you aren't allowed to drive it... ;)
You broke it?! Or searching for something called 'power'?
lol not broken! :P
just about to buy power fc and want to get a good service before that goes in prior to taking it for a tune :P
A current affair should be interesting tonight..
damn i wanted to see that but missed it >,<
Edited by bluejeans
lol not broken! :P
Phew!
Buy a pair of turbos while you're at it, and decent twin plate clutch. tongue.gif
als car needs e85
my bros on e85 now smells nice, does it make rear bar less black? looks like it
Is his the white r33 with white TCIIs? saw it the other night, did he get epad or something? Had a pea shooter spec exhaust on it lol
Phew!
haha well ill probably get the power fc tomorrow night then in the next few weeks ill buy some monoflex coilovers and a clutch, then when ive saved enough ill do turbos :P
also i just watched that aca story on hoons.. wow that was literally about NOTHING......
Busy man you are!
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
