They were picked at random before they knew what they'd be 'investigating'
I don't see the issue though, any half wit knows you're not supposed to live on takeaway/fast food, and from what I've seen so far, maccas shit is pretty good quality considering what you pay for it.
Eat subway everyday and guess what, you'll be a fat f**k before you know it...
Friends and I watched that Supersize Me doco a few years ago that shitcanned Maccas after the guy lived off it for a month...went out 10 minutes after the movie for, Maccas.
I think the only people that really have anything bad to say about Maccas and all the other fast food chains, are those with no f**king life.
Everyone else knows it's fast food, to be eaten occasionally, and that the rest of your diet/lifestyle needs to be in check before you even worry about how bad maccas is for you....
Don't like it, don't eat it. Pretty simple concept really
And supersize me was ridiculous...Like I said, live on subway for a month and see how thin you are...
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
