Sweet, my mates got a galaxy note, things huge, please upload a picture of you on Sau on that phone so I can gauge how big it is.
yeah i saw the note when i was looking at the htc one x - and thought 'f**k thats huge' and considering the one x is already bigger than the iphone using the galaxy note would almost be like using a tablet!
i took a pic for you to see difference between iphone 4 and one x - not the best lighting but meh it will let you see size difference..
Edited by bluejeans
lmfao anth i was joking. got a one x now.
loving it.
oh damn you!
what widget is that you are using for the wifi/BT/GPS toggle? the standard one on my galaxy takes up half a frickin page
its just under 'settings / android' and named 'power control'
not sure if that helps >,<
