ah about heat treating.
aluminium goes though a phase change only at about 500+degrees, so you'll be alright...
by phase change i mean change in crystal structure. i could be wrong though, need to flip through some notes.
forget what i just said. the aging is done at between 100-200 degrees, so yup. powder coating is bad yo.. unless, it only heats the surface and the wheel does not really reach 200degrees on the inside, you only bake the surface anyway, right?
yeah but after you come to a stop, so I do a cool down lap but still you can light a match off the rotor after you aprk it, 20-30 min later has to have warmed up a rim quite a bit???
I'm prob wrong, should bring a thermal probe to one and have a play
I wouldn't be game to risk it :P
Where to buy spacers from guys?
Instead of being:
20x10 +42
20x8.5 +35
I got:
20x10 +38 (don't really care about that - more baws)
20x8.5 +42 (7mm more in on the front than I was meant to be getting..)
So now thinking a 5mm 8-10mm spacer? where to buy? ebay have a fair few is matching the center bore of the hub important?
lol not sure if trolling jonoe? :P
Alex, cant they're already here.. got them 2nd hand and cbf chasing shit up - just the fron'ts I have a problem with they wont be flush at all so thinking of spacer.. if i really like rims maybe buy 2x propper sized ones and rip skids on the others or something lol..
If specs aren't as advertised send em back ?
eh got them at a decent price + cbf sending shiz back I think it was a honest mistake by him so might try some small spacers to push it out
ford have factory spacers anyway as dust guards on the rear lol
