Just le' Skyline and Barina at the moment.
Once things settle down i'll get a GTR for myself and a family car for the missus. Probably some sort of Beemer/Accord Euro or anything that is nice too drive that has 4 doors.
Who'd u go through tony? Blue Nile seems popular and i can't remember the name of the other place
Or did jeweller do it all?
+1 on the invite
Think he meant wedding cars brah
Edited by alr33x
+1 on the invite
Blue nile is good, I was going to buy it from there. Their stock range is massive, only issue I had was that you can't actually see the diamond.
I went with JamesAllen.com. They have pictures of the actual diamond, which is important if you are looking for inclusions.
From then you can pick a couple and then an opinion from a geologist of their opinion of what they can believe is the best diamond out of the few diamonds you have picked.
I spent a little more, 5-10% to go though a jeweler, only as they have a guarantee, ie when it arrives if I'm unhappy with it I can decline it.
as for tiffanies, the one we wanted there was close to 30K.....said jeweler is doing same setting in platinum for around 1/3 the price.
gotta have a wasteland table brah dont forget the invites :P
Just be prepared to bring a machete, as the last Viet/Cambo wedding I went to someone got bottled :wacko:
Yeah for piece of mind, being able to see it in person can't go wrong with a local jeweller. I would say when choosing a diamond, one with a GIA certificate is preferable.
Bluenile do offer a 60 day money back guarantee no questions asked, but being in America it would be a pain in the ass if you did have to return it.
yeah this is a GIA one,
we went thought a few found one that was right size and color and clarity, he investigated it was all good so shipping it over, he will do another check then we get to come in and confirm it.
plus he came recommended from 3-4 of Katie's friends for doing their custom rings.
should have finished product in 2-3 weeks
Don't know how you can still use a 3, mine was so slow by the time I got rid of it I was lucky not to throw it at a wall everytime I used it..
I'm still using a 3GS. Battery life is starting to die in the arse as I've had it for 3 years.
think the bike will be sitting under cover for a while
probably a bad idea buying one this time of year....
fyl
Sunday is looking dry, will try to organise a ride.
Got a picture?
You too Alex, somewhere on the T & Co website?
Our one should look similar to this one:
If it's that lighter coloured blue, then I think you should stick to silver wheels...
its gun metal grey with a bit of blue through it.
As long as Rimon is on our table we'll be fine
rofl.
hole cut under the battery in an R32 GTST for the intercooler, confusion as to whether i cover it up or not, as ill just be making a hole again after i get a rwc...
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
