My 33 GTR was use to driving on the light hehe..
I'd put my 50 bucks in.. get my 200k's lol
Nick! pics of golf!
there is some i put on fb, still waiting for the nuts for the rims to come in from Germany to put them back together
then I'll post up some in ride thread or something
good idea, got a few people that run muddies and they lose usually at least 100kms per tank with those tyres
they look tuff though
what nuts? i've got a set of used bbs nuts somewhere in the shed dont even know how i got em
mine has the light... i see it every time i change from 98 to e85 or vice versa.
with the return line going to a jerry can and a nismo intank pump that pushes 4.6 lt/m the time from when the light comes on to when you can hear the pump start to get loud is like 5 mins
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
