I called 3 dealers today and all said they have accepted deposits. RRP is not released yet but prices are said to be below VW golf Gti price which is $38,000
A dealer from NSW is a member of the ft86 forum or whatever it's called, he's been told that people will be pleasantly suprised with the price. I'm happy to pay $35,000.
Deposit will be refundable... Probably be like $500 or so. Once I get it than I'll try sell the 33
Fark...I want one but I'd probably have to sell the bike or Skyline, the former being too young in my possession and the latter not being worth selling. I have three regos/insurances as is :/
Rego should be for the driver not the vehicle :/
Are Subaru taking orders too? I was torn between who you'd go with. Subaru know their boxer engines (servicing etc.), but Toyota had the best exterior look IMO. Subaru interior looked better from concept pics.
Probably best engine under 140k
err, i THINK ou are forgetting the mighty RB20!!!!!!!!!!!!!!
revs to 11ty and makes POWAH!!
best engine EVAH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
R32 for life yo
I reckon, 286rwkw stock and with a re-map of the factory ECU +100kw gains to be had.. awesome grunt
Let me know if you find any TE37 superlaps 19x10 +35 ish.. and 19x9 +20ish or any good looking rims really, also 20s are good too
For those that are thinking of buying an 86, what has swayed you into buying it?
As from a car enthusiast point of view one could argue it doesn't offer better performance/handling of the s15 of 10 years ago.
Understandable though if you want that new car purchase, updated interior and arguably less cop trouble.
In saying that I hope it is a success, so other manufacturers can bring out cheap RWD coupé sports cars.
Too bad it only comes in a family boat!
Emotionally, for me it's the idea of a brand new, reliable car with modern everything. It wouldn't be as fast as my Skyline, but everything else would be better about it. Lowered on a nice set of wheels and I'm done. I've hated the look of new cars for the last 10 years...everything looks like a mish mash of ergonomical f*** up compared to the 90's and early 00's. Toyota haven't made anything good looking for 10-15 years IMO.
Logically, it's the answer to the question, what do we have these days in the way of good value sports cars? All the traditional Jap imports are getting old, unreliable and boring. In the new car market, anything good looking (sweet f*** all) and decently quick (370Z, STi, R32) is a $60k+ affair. I think this car will have a brilliant little niche to itself...perfect sports car for young people.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
