Too bad it only comes in a family boat!
It's a not so bad now that I have coilovers on it, the biggest problem is they only come out with 245s just need some fatter rubber.
Still heavy as fark but you do get more space
Attention: Mr Toyota
Make a f**king supercharged one.
FYP
Frankly I'd be glad to get back into the linearity of a non-turbo car. There will be aftermarket turbo kits for them not long after their release.
I can see all the hipsters driving 86s and yuppie type wanna bes stock ones that is
Yeah!
The new kid on the block type of attitude, thinking it's the best shit of all time.
Betcha if ya asked them what a AE86 let alone a 4AGE, they'd be "WTF?!"
Buy a car that is already turbo'd...
Nothing wrong with turbocharging a car that didn't come with a factory turbo model :)
I can see a lot of old guys buying them actually, the new mid-life crisis car.
What's your thoughts on turbocharging a N/A Skyline?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
