Anyone ever seen that plastidip shit in person?
Looks to good to be true, but if it peels off the windows that easily what's to stop it doing the same on your panels?
I guess people wouldn't know the difference if its done right. And it's only that easy to peel off if it's half cured I think. Meant to be a bit harder or almost like vinyl when it's on for a few hours
Would do the EA for a laugh but I'd say the paint needs to be good to begin with, or prepped, and I won't do that
Yeh I think it needs to be pretty well prepped like clay bard or something. But I would do a panel that I have laying around at home first before I attacked my car
Got 2 mates that would be interested in doing in.
What sort of costs would you be looking at to do the plasti dip?
Well after checking my bank history turns out I never actually confirmed payment, so I'll probably buy it in a couple of weeks. I'm happy to do other peoples cars but would want to do mine first to see whats involved and if I actually do a good job for starters
Lol I posted a picture and they all started crying because they are varrstoens. Took them a while to figure out that it isn't their car. Lol
Yeah cuz Varrstoens aren't JDM AS FUCK!
Actually an NS member posted a topic about ROTA Wheels.
Was an interesting read.
Don't be mean they will cry
Lol yeh man I'm sick of the debates though.
LOL!
Yeah, once you're on NS for a bit you can actually filter out the shit.
I like NS.com, there are some good members on there who know their stuff and you can find some interesting threads.
I think I will now
The thread topic is usually a straight up give away if the topic is going to be good or not.
Then you read the first few post, if it's all shit talk = Shit thread.
Constructive discussion = Good thread.
Nisskid has the know-how.
In one thread, he was explaining to us about the types of wheel qualities and builds through out different brands.
I just asked them where I can get volk rays stickers from
LOL! For the trololols!
I bought a sticker set from On The Run Motorsport.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
