no shit. my dad calls me at 7 last night and sez he's gonna be late coming home from work and to tell some dude that he was expecting to visit that he'll take a raincheck. cool cool. so i head out to play some indoor. check my phone after (11pm) and find like 20 billion missed calls from mum. apparently, he had fin work at 4, gone to the docs and was ambo'd to the hospital. they admitted him and held him there for 6hrs then sent him home. first thing he did when he got home was to fill up a glass with scotch. by the time i get home he's passed out drunk on the couch.
for added context, he's had a major heart attack last year.
typical curries bro. my dad doesnt drink though, so hes always complaining about shit.. best part im helping him and hes saying me n my sis stress him thats why lol
worst thing about old bikes is lack of aftermarket parts/accessories
There's plenty! Your bike in particular might be hard to find something specific to it, but a lot of parts are universal or fit multiple model.
Tyga have a bunch of stuff for the zxr
Some ideas in here
http://2fiftycc.com/...opic,729.0.html
they only have the conversion fairing kits and spare parts for em
i see
found some stuff on bikebandit.com
ebay is gay
Stock catback I bought didn't fit :(. The brackets/bolts don't line up, sigh. Mate reckons my pre-cat piping may be straight from a GTT as well (along with rest of my exhaust zz).
Drain. Looks like may have to take it to exhaust place just to cut it, line it up, and weld it back on :S... So much to do, so little time >__<.
Anyone know the boost limits of the standard R33 GTS-T bov? Starting to get compressor surge at high boost.
14-18psi from what I've read in FI section.
Grab yourself a GTR bov, looks stock and will hold high psi no probs.
On another note, I'm impressed by what people drive around in Prague, really impressed to be honest!
Was told its bolt on into the cross over pipe, after seeing one up close, I'd say it's bolt on.
I'm sure Ash or whoever will confirm it 100% as my memory is bit fading... Damn European beers!
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
