to celebrate Italia's epic loss i've bought a pair of lotto futsal shoes in blue/white.
look forward to trying them out tomorrow and get complimented on them by all the Azzuiri fans there while i go around collecting money that they all owe me now.
cocky kunts never end up on top.
twas a good day
not member - cliffs notes pls
Some dumbass tried to justify his 'hooning' or whatever from the meet on the forums, everybody tells him to shut up and now that guy has threatened somebody because he doesn't want to accept that he is in the wrong. Aaron's gone and made some funnies about the situation.
As usual
twas a good day
2006. And 3 previous
Cool story though
I love how all these non Spanish kunce have to live through Spain's win because their own country either wasn't good enough to get anywhere near the final/got knocked out by Italy/both
Feels good
Sensible Italians know we were beaten by a better side on the day. They playe d well and we played poorly, so we were never gonna win with that effort.
Add to that a days less rest, which lead to injuries leaving us with 10 men for 30+ minutes.. obviously they pretty much had it wrapped up by then but obviously being a man down against a team like that is going to end the way it did
Italian fans can be happy with how we played in the tournament apart from in the final itself... and we lost to the best in the world at the.moment, so that's nothing to be ashamed of
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
