Think the only difference between the plus and pro glove is the hard cover on the wrist strap...Dude at Peter Stevens told me not to bother with them over the Plus..
And the Pro is $250 like the Dainese Joust....
I said I want all that, not that I can afford it.
I was devo when my favourite Indian restaurant in Croydon had a mangled, diseased mouse walk around my feet while I was eating. Haven't eaten there again :(
indian restaurant is indian restaurant....
eat there at your own peril
/racist slur
You have PM Tony.
I tend to get popular this time of year
Haha just caught the ending. Imports chasing motards? We need an orange supra not an orange Silvia.
Speaking of Orange Silvia's, Why hello there Aaron
http://www.facebook.com/photo.php?fbid=494768280549553&set=a.316928381666878.95883.310660842293632&type=1&theater
Lol no deal
Wanna get the gp pro gloves
Dainese gear too expensive rich kunt ^
I recommend RST gloves, way more affordable than Dainese or AStars, great quality and fit a billion times better imo. UOf course this depends on your hand shape but I find any other gloves makes my thumb to forefinger movement quite restricted. They also look sick and match other gear well.
Srsly though just get something good quality that fits well, no one is going to notice if your fashion is out of line :S
Yeooowww. Was good to meet you Leigh. Fun ride, I would have opted for a few more laps but the ride around the peninsula had worn me out. I actually recommend it down there as there's not as much traffic, not so many corners but enough to have fun and no cops. In the end you're going 200kmph in between sweet spots so it works out to be the same value.
Hah, yeah Birds I was surprised you were okk in your gear. I had.... two pairs of socks with plastic bags over them, full length tights, then bike shorts, then full length skins, a singlet, tee shirt, full length skins tee, a hoody, and my leathers over all of that... plus a scarf and normal gloves under my bike gloves haha! And I was f**king freeeeeeezing! Spent and hour in the sauna tonight thank god for that.
Also, just found out my mates mates 1198s is sitting in the garage and is here open endedly to play with... we should go out again soon!
Oh didn't know that was your first time meeting Leigh, my bad, should have introduced.
I was fine yo, I usually go up there at ~11pm when it's ~2 degrees...now that shit is cooold. You have access to an 1198s and have not taken advantage of this? daughteriamdisappoint.jpg
http://www.facebook....&type=1
Mental picture of Tony around Christmas time sitting at a table alone, with a bottle of scotch :P
its funny coz its true.
sri lankan restaraunts are generally clean.
lankan / indian = completely different
lankan food destroys indian
aint nuttin wrong with drinkin scotch alone.....
It only arrived last night. Getting rid of the Daytona tonight so that I can have the excuse to ride it tomorrow huhu
I prefer Bourbon or Cognac brahs
Haha that's an awesome pic, I might use that one
If I'm feeling baller
Though because I'm not a hard k*nt and like to mix my drinks rather than on the rocks, $60 Hennessey VSOP rather than a $300 Hennessy XO will do
same price range - buy Chabot VSOP armagnac
10x better than Henney VSOP
and drink it straight - fairy
Results today. Passed all, so no beating from the parents tonight (Y)
Parents usually stop caring after Year 12
Cognac = good
Bourbon = bad
what kind of classy guy are you!?
Bourbon is there when you don't have access to Cognac. Not gonna go rolling around a club and ask the bartender '3 Cognacs please!' :P
I am a fairy, sorry brah :(
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
