this is the bit where I say I got paid to go to the nurburgring and octoberfest....
don;t worry when u lot are as old as me it will seem boring.
oh just heard from work,
looks like going to HK on the 23rd as well nice..duck tastic
spent like 6 hours detailing the outside of my car today, maybe tomorrow ill do the inside :/ though it just needs a quick vac.
gotta buy some oil and do a service also but id rather do it all when all the parts ive ordered arrive and do it all at once
also
motorbikes, gaylegs etc
birds, convinced my other mate with a r1 to buy a motard at the end of the year after he rode mine haha.. get on it! /trackspec r1
any other wastelanders meeting up tonight in doncaster? I'll probably go for the meet but not cruise
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
