yo hamish, i want some good pad thai, places to eat kgo
padthai craving needs to be satisfied
When I used to run Mopho, we got named "best pad thai in Melbourne" by John Lethlean - former cheif editor of the good food guide. When we left we taught the new guys how to make it, and i dropped in recently and it still looked the same, but i didn't taste it
Look Hamish, no hands
overcooked yes, but as it's Birds I am proud!
you've come a long way baby!
next time leave the meat out of the fridge for an hour so the whole thing is room temp first and then you can acheive the doneness you want in the centre with less massacareing of the outsides.
also rest it longer
Will give that a shot.
You've also come a long way; baby.
lol yeah.... a year ago I would have just shitcained you for cooking it that much.
working at a bank really calms the ol chef temper
hamish. knows. food.
few minutes on either side is enough for me :D
Have to take you to stone grill brah, each piece you cut cooks to well done in about 30 seconds. Even then, it only has the texture of well done with the flavour of medium-rare because the meat doesn't really have a chance to dry out.
For true medium-rare you could give it a couple of flips and straight in the mouth...
I was referring more to the "baby" situation with my clever grammar insertion...but you have also come a long way from the angry chef I used to know.
Yeh lol stone grill is harder to control heat.. But I've been and it's great. Only reason its cooked more though is also because of how small their cuts are
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
