not sure if you were still there, a wrx touched the grass coming on to the pit straight, lost it and went backwards into the wall hard.
lucky he had a cage.
I'm sure he had no idea he was dropping oil as he went past the pit entrance twice whilst it was happening!
yeh i saw that.. the red one? pretty much lost the rear end of his car poor guy.
nah the guy new he dropped his oil.. according to the towie, he'd lost 4th, couldnt take it out of gear and from what he explained to the towie, he saw the oil out the rearview.
the fact that he didnt drive into the pit but instead continue along the straight is pretty dumb if you ask me. surely you'll know somethings wrong if you cant get it out of 4th.
It's worth it every time you press the quiet button on the remote. I can't believe how quiet mine is closed, almost stock noise level, not bad for a 3.5 inch muffler. Even open it's not too bad.
Hrmm maybe i'll drop past sometime! it is something useful to have for starting up in the morning so you don't wake neighbours, cruising down the highway, having elderly passengers or driving past cops etc....lol
do it.
lol everyone jumping on the Varex wagon now...where were you two years ago when I was pushing the things. No one believes how good they are til they drive a car with one.
Good value considering the remote controlled motor setup too Birds. They do sound a bit tinny when mounted at the rear, like they have a sock shoved up the pipe. Probably best if you can get it fitted as a centre but there isn't much room there on a skyrine.
Since we are on the topic.
When fully open, what effect does this have on the exhaust flow? Something small in the exhaust even when open will have some sort of effect?
When its closed, are there any effects on choking the system? What happens when you boot the car when the exhaust is closed, are the any possible side effects?
what was that? "Mr. f**k the remote and motor ill cut it off and make my own"
well scotts tune seemed to lean out when he put the varex back on, which means it should have more flow than the 3.5" muffler he had on before.
threoretically you want the exhaust to be quiet when its closed right? so you wouldnt really be booting it anyway. but with the flap closed, the car is a laggy POS Lol
When open, it acts like a straight through piece of pipe. As it uses a butterfly valve the restriction that would put on it when open is SFA. I have the 3" Varex and ~260rwkw no issues with flow there.
When closed, they say not to drive on boost. You can give it a couple of PSI without harm, but you only need to use closed when popo are around, getting home late or cruising on the freeway to avoid drone.
Is yours a cannon type or twin tip? They do make different sounds and have different valve setups. I have no tinnyness to mine; think it helps that the rest of my system is mild steel.
Okay well that's the same setup as a canon type and they do have more of a stainless steel to them than the twin tip.
yeh the twin tips are quieter, but i heard them on a friends car and didnt like how they sounded on an sr(not that it would ever sound great - but better than its worst) but that whole sound went out the window with the .82 housing lol
and then the gate.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
