As for bikes, no test ride without buying seems to be the norm...bit risky but hopefully nothing is wrong
Oh I wouldn't buy one without someone else at least testing it. But turning up with the money to show you're serious helps, as does saying if it rides well then I'll put a deposit down. That said, if it starts/idles/revs fine in neutral it is generally going to ride okay too.
I'm down for a SAU poker night! or could even meet up at crown one night and play some
I bought my DRZ400 after a quick ride he didn't want me going far though, and my GSX650 was from peter stevens so they didn't let me ride it - that being said I did ride a private seller one to test before I bought the dealerships one
When I rocked up to see mine, I was pretty much buying it if it was what he'd advertised....
I asked if my mate could take it for a quick ride to check it out, and he said not til you pay which seemed pretty odd to me...But it was practically brand new so I wasn't too worried...
People just worried about you crashing it and having no recourse, cause a lot of people (stupidly IMO) cancel their insurance the moment they put it up for sale. I understand avoiding test pilots too, but when a buyer turns up with money / serious about purchasing, I'd be grabbing their licence, writing the test ride up in a deposit receipt and letting them ride it.
Yep, a lot of people also believe that it's not covered if it's someone else driving...But I read in one of the insurers booklets (would've been Shannons or JCI but I'd say they all have the same policy), that if it's a test drive it's still covered.
I told him on the phone several times that if I'm driving almost 2 hours to check it out, I'm not driving home without buying it unless it's not what he'd advertised...
lol had a customer on the phone - FOB chinese, he had to be called back by my manager (slightly FOB sounding cambodian/korean) and the dude says "awwww your accent, are you from scot-a-rand?"
rofl
Makes sense. I'd keep insurance up even if other riders weren't covered. Willing to bet a lot of bikes for sale get stolen after a "buyer" has seen where you keep it / how it's locked up, then you're fked.
The guy that bought my GSX was first to inspect, didn't ride it looked at it for 10 minutes and offered me 500 dollars less than asking price without a RWC so I naturally just took it, rocks up 2 days later with a trailer and tows it back to Geelong (he was a new learner and wanted a bike with some balls but not silly power)
My dads old motoguzi 1000cc got taken for a test ride and the guy dropped it.. then didn't even buy it but offered to pay for repairs, heaps of time later he could finally put it back up for sale after the head f**ks.. kind of annoying if you drop the bike you better f**king buy it IMO.
This was in the 90s, I use to love going on the back as a kid. (similar to this bike)
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
