That sounds pretty decent :thumbsup:
Yeah I don't think I'd be getting close to that.
I wouldn't rate myself as a driver.
I'll be turning down the boost in the R34GT-T to 10psi so should be making about ~170rwkw
Would you be happy to be my driver trainer in the morning :D?
Happy to do DT
and I was def not a good driver, slowly improving now but yeah went from a FWD bluebird to the 200 and hit the track straigh away...very fast learning curve, should ahve driven it for a year or so first to get a better idea of how it reacted.
thus why on my 2nd or 3rd day I ended up liek this:
Happy to do DT
yeh but you atleast had some experience lol
reply to my pm
Software
yeh good coin in that mate of mine is cleaning up, off to silicon valley cos he is like one of a select few who can do what he does, dont ask me what it is i barely know how to get online
Not going to watch... I'll be at world time attack watching drivers who are way better than you spuds
niceeee mint chicks there to based on last years pictures
for the past year or so my eyes have been hurting heaps.
last 3 weeks its gotten to the point where i sometimes wear sunnies in the office.
my eyes dont like the light.
going docs tonight. better not be going blind lol
kgo sau doctors.
vampire
Really?
I would have thought it'd be alot faster? Doesn't it have the best of everything? Engine, suspension etc...
Chris Thompson does 1:17 on 340rwkw in the 33R
ya but remember Christ car on semi's and stripped out of sound deadening and such so makes a big difference.
there huge diffrence between street and track set-ups
that said power at sandown does rule.
Winton much less so.
haha just found my drag times from the last SAUVIC drag day.
Managed to get 18 runs in, and i recall having enough and ending it early.
No waiting in line due to small amount of cars.
When's the next one?
What times were u getting?
Well turns out not a big tax return as expected. HECS repayment based on income pre-negative gearing.
The money I spent covering the gap between interest repayment and rental income + rental expenses is much greater than the tax return achieved through negative gearing.
I doubt property value would have increased over the year too...
Should have bought a motard
/first year investment
Didnt know you were into motards! they're BAWS
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
