Favourite scene in the whole series
http://www.youtube.com/watch?v=_YWR-CNe19k
Yeah im not working at the moment either.. gets pretty boring at home
Hey wanna go for a ri...oh :(
One of my favorite lines in the whole series is when Tony gets shot and they're at the hospital...Paulie says to Meadow and Anthony Jr
"It'll take more than the Jamaican bobsled team with cap guns to stop your old man"
Which reminds me of another classic Paulie line, again at the hospital when Christopher gets shot
"Do they know this kid likes his chemistry set a little too much?"
insatiable
ty
Another classic is when Pussy says to Christopher I think it was...
"Why would he wanna help you, considering you put a fookin moon-roof in his head?"
best part was when ge kurb stomps that guy in the diner
lol yeah the hospital, I lose my shit when he's paranoid about going to hell; starts interrogating Chris about it. "Was it hot?!? The heat woulda been the first thing you woulda noticed. Hell is hot. That's never been disputed by anybody."
And when he cracks it at the psychics haha
You asked how much, but not specify 4cyl / 6cyl.
$580 for 4cyl.
i said it like that because i already searched it lol.
$20 difference is pretty gay. but if you need them, then you need them.
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
