exactly, but not one of you can do anything about it? lol i find it funny that the only person that can is the one that says "I dont get paid for it so you cant expect me to do it as pleased" why doesnt he give the authority to one or two of the other execs who will and "have the time"?
/end rant
Edited by Sunkist
Ask Richo if there is a spare role, not sure if there is at the moment. But I may be unaware
As for the above comment I agree, already been down that path brah :/
There's alot of stuff that goes on behind the forums re issues and complications that are always discussed that the general forum users are not always aware of
Edited by blah_blah
Not a lot we can do about it, SAU Vic is a seperate entity to SAU; Ash being in charge of the latter and he has never wanted to delegate forum power to SAU Vic execs, so you'll have to be patient :)
Lol I don't care about being an exec I was annoying you.
But passionate about people paying for shit to support the club, and not have a prompt return.
When u go to Coles to get eggs you don't pay for them and have to wait 10 days for them to become available.
There should seriously be someone else handling all of that if that one person isn't enough to keep up. It's probably half of the reason why people don't bother becoming a member
im considering not renewing my membership.
we need more events. clubs dying.
Not the club the cars dying not many fks are given rembering it's a 15-20+ year old car in most cases
How many cars of that age have big clubs/memberships
The Club has no say in how the forums are operated or managed. The forums allow each club a unique area for their club members, however forum rules still apply within those areas and ultimately the forums still control those areas, though the clubs do have some moderation control as well.
We make requests, just like any other forum member can. That is as far as we can go.
I do hope that the situation changes for the forums in the near future to improve the situation. As the last 2-3 months have not been great forum compatibility wise.
Spoken like a President lol
thats exactly right, but the fact that the moderators wont expand their teams within the Club exec's is pretty poor form, its nothing against the club itself, but more the moderators running the show.
its a simple task, I'm sure that it doesnt have to go before Julia Gillard to grant moderator access to someone such as yourself, it probably doesnt need to go before anyone for that matter, and its a selfish act for the moderators to restrict members access to something they've payed for because they can't be bothered doing it.
There are plenty of people trustworthy enough in the commitee team ie, yourself toby Dan etc, that wouldn't walk around like Mad082 waving their banstick around to justify their ego.
nothing against the vic club, if it was I wouldntve renewed.
/SAUnion
Edited by Sunkist
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
