don't like bbs mesh style rims
mixed opinions on the varrstoens, lots of haters hate with jap on ford lol I always liked them since I got a set for my old GTR
Sell Ford and buy GTR.
toyota 86 dyno run...
You'd want that over your RB20?
Tax Return has been processed by Ric
Should hit your bank account in a few days
It went to Ric? lol wtf, half of the wasteland handling my tax affairs
Just spent another 2.5 hours in Rimon's territory aka roof space. I love that shit now.
to the 86 dirvers, is the "awesome driving experience" simply because the thing is so underpowered that you just leave your foot on the floor and turn the wheel?
srs question...
my ksev was like that and to have fun you had to treat the clutch like rodney king
Nah not really, I just like to call the Tax Office as Ric :P
srs question...
lol, the GETZ is just like this. Love it.
Foot the to mat, you can hear valves bouncing around in the high revs. Very little sound deadener between you and the engine.
And...your still way under the speed limit. ha
nah... i'm cool
I'm probably as close to arachnophobic as you can be without actually being arachnophobic, but if I can't see em it's all good....I was lying on my back/side/stomach for the whole 2 hours, in the smallest part of the roof space, in a 25 year old house, so I know they were more than likely all around me, but I didn't see them, so we got on just fine.
He seems even stricter than the ATO itself so thank f**k he's not the one doing it. Mine was all legit as you would know be aware :)
leigh... meisters/professors...
do it
I do like me some meisters / professors.. they're so nice
http://www.importmon...roducts_id=1304
Should try these on.. only issue is the rears.. they'd stick out 26mm more than my old 20s I had on lol.
On another note, cars booked in for tune on Wednesday :D
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
