Fark biggest headache
That chick that scullled the drink at the end of the night had to have a spew bucket with her all night
The look on our faces when she did that.. seriously dafuq. And that was a bet you lost, should have drank that drink mannnn
Haha tony after seeing you smeshed I dont think I'm ever going to be able to take you seriously again
Still want me to do your taxes haha?
Yeah feelsbatman.jpg. But that was lethal. Next time moh
birds I wonder what first gear on an r6 go to? clutching in tight corners doesn't sound fun :P
Just means you have to go faster! It's only Arthur's seat I've ever needed to clutch in on...and that will change once I drop my front sprocket down a tooth :D
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
