haha I wish I could get into sales.. unfortunately I've spent the last 5+ years doing I.T and think it would be very difficult to get out..
Excuses excuses :P
Out with the old
In with the new
Pazzo shorties feel so nice to grip. Adjustability is awesome and they look more factory than the factory levers.
It's comin Rim, it's comin! :)
yeh but wasnt it also that 7 or 8 had shitty gearbox's or something? someone buy me one.
Nope 7s have a 5 speed which is a little stronger as the syncros are a bit bigger
But it only matters on 300kw and above, actually easy to crack that power however
Think I made car too low :( - worried about bending lip back on driveways or speed bumps now :/ bah looks so nice though
Talk to me when you scrape crossmembers :P
Golf <3
haha cling wrap your cat dude. im still waiting.
Haha sticky tape is good too, need to only put on one side, whether it be left/right, underneath or on its back and runs the opposite of where its stuck lol
EVO vs GTR = 2 different types of cars.
One has a larger displacement with 2 extra cylinders and 1 extra turbo.
This, evo is a more 'responsive' car generally
GTR isn't full time 4wd like the evo and its bigger engine with twin turbos it far less responsive than a evos twin scroll
do it then get an evo 6!
I'd suggest later than 6 if you plan on modding and its primarily a street car, from 7 on wards
$350 to retune factory ecu from Burnzy compared to swapping for a new ecu like power fc etc or changing to a 7 ecu into the 6 (about $3k if i remember correctly plus tuning)
Also the AYC diff is so easy to drive with, and its a newer car better interior/nicer looking etc etc
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
