What part of Newport you in? I grew up there just between Maddox / challis streets loved it.
I hate up near mason street and beyond mason street really is crapola there
Best is willy side but $$$$
Tried to get a test drive of the Toyota 86, failed.
Dealer want me to lay a deposit and be prepared to wait for 18-24 months for 30 grand Toyota, no thanks.
Mirls st location is awsome, but I need more space.
thinking moving out sunbury way next year.
as for my work, close to airport is more important than close to office.
lots o space for not much money.
Lol if you were serious you would have not been turned away by the deposit bluff. He could tell you just want a joy ride haha
Great spot two blocks from where I was!
surprised to hear it going backwards
yeah when I moved in I was the youngest person for 6 houses at least.an
d def only one with jap car.
now it become cooler since Willy over priced, so yeah def going downhill
plus rent nearly doubled.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
