f**k this threads dead today
Perform a CPR.
On another note, f**k, I need new work pants even though I've bought couple other days, it felt shit and makes my genitals all over, I had to adjust it every f**king minute...
get some new jocks brah
No issues with jeans, tracksuits only this stupid useless 'business' type pants...
Might have to go one size smaller me thinks, time for another trip to clothes shops - f**k it
When i was a kid i used to wear boxers, did karate when was young and eventually when my balls dropped i needed to upgrade to breifs :(
You need an ipad or something for the train play some gameeeeees
18x10 +38 nick :P
yours should be this low!
That's bagged out, just like most of the US cars, also no way in hell he is running 10 +38 front won't clear strut. I'm pushing it with 9 +35
my rears are 9 +22 so will sit 3mm more out
I reckon mine sits at a good height atm, will need to post up a side pic soon to confirm for wastelanders
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
