Who is good with wiring and shit? Cluster and window switches died on me yesterday, some chewed wires in wheel arch loom (dat stance) but I joined them together again with no success. All fuses under dash and in engine bay are sweet. Help plz
You should probably check those wire properly and make sure they haven't broken elsewhere/are now contacting properly.
I rubbed through some of my loom and lost my cluster, windows etc.
They only appear to be broken in the one spot, the rest of it seems fairly well insulated. Was it just that bit of the loom that was your problem?
Yep was only the loom, took a spur of the moment late night trip down the GOR. Cluster and electrics died and kept driving, then the car died and wouldn't start back up, ended up getting the car towed to local racv blokes shop and staying in Appollo Bay courtesy of racv. Walked to the shop next morning, taped everything up nicely, tucked the loom and drove home.
With those km I wouldn't pay more than 8k for it.
Yeah I'd always be offering 1k less and never pay list price, it's expected lol
rather pay $10k for this
http://www.bikesales...3624E8&__Nne=15
Too old brah something about riding around on an older bike would make me feel weird / paranoid something will fail when doing 110+
Can't just be me?
Bit more for one of these!
http://www.bikesales.com.au/private/details/ducati-848-2008-12920871?__N=1432%20604%201430%201429%201626%201428%204294967242%204294966239%2082&__Ns=p_PriceSort_Decimal%7c0%7c%7cp_Make_String%7c0%7c%7cp_Model_String%7c0&__Qpb=1&__sid=139F477975AA&__Nne=15
birds have you got full comp on bike? thinking next bike will be well under 10 again and i'll just get third party again (thankfully i had it last time).. cbf paying 2 full comps / full regos
Lol hardtuned meet. Everyone said there were no cop issues, everyone was behaving. So I decided to go. It was really good...
... For 5 minutes.
Then the launch control contest began, and who can do a skid the best. People were actually doing skids, leaving, coming back, and doing more skids..
What a fail.
/csb
... For 5 minutes.
What a fail.
/csb
heard a few peeps got defected. Any confirmation mah nigguh?
Don't think so, it was only a divy Van that rocked up and told people to leave.. I went back in the missus car hoping to see someone face plant a wall, but it was literally emptied.. So I doubt that anyone got defected.. There was a chaser that did at least 6 laps of burnouts lol
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
