whilst the actual personal enjoyment level would be quite low (dose thumbs).
(dose thumbs)
(dose thumbs)
(dose thumbs)
(dose thumbs)
(dose thumbs)
(dose thumbs)
(dose thumbs)
(dose thumbs)
fox.jpg?w=548&h=359
So question for those who know things about club rego. I know it says 25 years for manufacture of the vehicle, does this mean it doesn't go off the model of the vehicle eg 1989 R32 will be able to get club rego before 1994 R32?
Well that is annoying :( Jamie can have club reg 5 years before me dun dun daaaa
Are you going to be interest in club reg through SAU VIC?
why do i keep seeing mohomo's car referred to as widebody on my fb feed
i aint seein no widebody? or is rolling ya guards flared these days?
His widebody comments are in reference to using GTR guards
I have heard rumours that if the car is based off an earlier model it can get club rego. For example, if you build a replica of an AC cobra, even though its brand new it is based off a 1960's car.
So going by this theory, if you build your 1994 r32 to replicate a 1988 r32 then you should be able to? lol
From vicroads website;
The Victorian club permit scheme allows members of car clubs (including motorcycle, trailer/caravan and machinery clubs) that are recognised by VicRoads to make limited use of historic vehicles on the road network.
A club permit can be issued to the following vehicles in the following categories:
  • Veteran vehicles – manufactured before 1 January 1919;
  • Vintage vehicles – manufactured after 31 December 1918 and before 1 January 1931
  • Classic and Historic vehicles - manufactured after 31 December 1930, but more than 25 years before the date of the application for a club permit.
These categories can include trailers and modified vehicles such as street rods. Vehicles which are replicas of vehicles in the abovementioned categories may also be issued with a club permit.
I was thinking classic skylines, I wasn't aware that SAU VIC even did club rego :) Hmmm yeah that's the grey area I was reading Pat, not sure what the go is there I might send off an e-mail to someone at classic skylines to get it clarified.
what if i was to say that my R33 gtst is a "replica" of an R31 GTSR jsut a REALLY bad one ;) ... who decides on this?
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
