thought i'd give 5th gear another shot... .(after being turned off by all the presenters not named Tiff..)
First story....
FIRST f**kING STORY
and that stupid woman is giggling and screaming
topgear withdrawal symptom lol
unsure of wage, thats negotiated based on your experience.
Call it whatever you want, any job can be simplified and undermined but im not going to encourage such childish behavior.
Best to think about the positives; be it a foot in a door, easy job in the city or chance to explore what fits.
Hey Patrick,
Mind if you PM me the details? May not be an engineering job but this could be a starting point towards my engineering career with the company. :yes:
i hate when people try to say "it's like top gear for real enthusiasts"
no it's not.... it's like top gear... period!
only difference is the smaller budget
I found earlier episodes of it more information based and back then it had distinction from Top Gear...but later on they tried to borrow the Top Gear formula and, like all the Top Gear spin offs (I'll pretend Australia doesn't exist), there is no need to do that while the original is still running.
RPM on channel 10, now there was a show from my childhood. Used to watch it eating hot jam donuts I'd picked up from a van on the side of the road.
/nostalgia
/nostalgia
Nothing beats the maxi donuts at Dandenong Plaza outside of Games World. Rolled and coated in so much sugar. Epic
The place has since been turned into a socks/jocks stall :(
queen vic market donuts...best by far
What were u doing there. Dandy plaza is a f**king shit hole lol
I was just asking, and given the response it sounds like i wasn't far off the mark :)
what were you exactly asking? The job description was posted prior to your 'question' which obviously was tailored to be a statement rather than a genuine question.
My response to your statement is not a confirmation of your thoughts but to question your real intent for posting such a comment...
On another note, just purchased an eye-fi wifi SD card.
http://www.eye.fi
SD card with built-in wifi which will upload photos to iphone/tablet automatically.
Planning to use it alongside my DSLR and view the photos on my tablet.
Nothing worse than coming home, viewing pics on computer and noticing they are all blurred or too dark >.<
My first world problem is having an Iphone & Android tablet. Shit is too complicated to make them work together. Best to have either all apple or all android...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
