Haha
If you want a good selection of international and local beers hit up purvis cellar. There is one in Surrey hills. Massive range
I should pop in and see what they have.
nope...
the reason you cant get it outside bavaria is because they cant keep up with demand without risking the quality of the product (they are using the same equipment for hundreds of years to create the flavour)
in a hot summer they will actually run out and not even be able to supply munich :O
:O
I wonder what else do they sell?
Trying my hardest to remember what else I've tried while I spent time in Berlin, Munich, Cologne.
Schoffolher something
Berliner Pilliinser
Berliner Kindl
Plenty of others I've tried but forgotten the name >_< Having same problem remembering almost all of Czech beers as well, they're decent but not the best though.
Drove to Geelong for work, thought f**k it portarlington for some snapper.
sat through a few hours of icey cold rain and wind. Hooked up a big one, brought it up to the rocksat least 3 or 4 kg,grab the net, he spits the hook. FFFFUUUUUU
2:30 out of fkn nowhere
fighter pilots easily the coolest job in the world
agreed - (that or anthony bordain's job)
Ham you know a Ryan? Plates BFLAT
yeah.... if you see him tell him to come to my place and pick up his bar stool
man vs food...
burrito chalange (in knoxville)
burrito:
2 lbs pulled pork (900g)
1 lbs beans (450g)
1 lbs coleslaw (450g)
1/2 lbs cheese (220g)
4 full size tortilla
sides:
1/2 lbs mac'n'cheese (220g)
1/2 lbs bananna pudding (220g)
1 hour
that's a total of just over 5lbs (2.25kg)
never before complete (adam richmond was aparently the first to manage)
how ya reckon ya'd go dezz?
i reckon i could do it
first up a disclaimer for some unknown reason i'm adicted to thsi show.
BUT
I went to one of the resturantants from the first season
Nascar cafe in Las vegas.
2nd disclaimer I went as I saw this and thought wtf.
then I saw
and decided the 1 lb of bacon was probally safer.
anyhow I went not long after it started and they had their challange burritto.
Now on man v food they said only 2 ppl had ever finished it I think
anyhow I saw 3 ppl finish it that one night.
so there a little too much creative license
but I just watch to say oh hell no
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
