Why does it sound like a tractor and have such a high pitched spool? Lol
Deff gasket is gone somewhere.
Hrmm.. Unless you break Moh's legs he might edge you out and get the Show n Shine this year!
Speak for yourself. I've already had two final inspection days this year :P
Get a discount for being a SAU VIC member?
If not you can buy me a Thai Chicken Curry at the next GC meet for the monies saved :P
Haha, I'm going 6yrs straight now. Lets see if his survives the time haha
Wasn't aware we had discounts at final inspection?
Isn't your job detailing cars? You should be able to do your car easy!
Doesn't need to be clean at all. Only clean ones from wastelands might be Aaron and Adam
Everyone else might be rocking up with dirty cars :P
When isn't my car clean. Even when it's dirty it's clean. I never understand
Lol Ex Detailer!
I used to use all Hondas things to detail my own car, I don't own a buffer, well one which works :/
Might need to try grab one before then
lol sadly :(
im just going to leave them and get a guy who does full wheel restorations to do them in a month or two
they are all awesome condition especially the rears, its just front left which has some clear gone lol
also nothing will take the brake dust off lol
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
