i might know someone.... what does the job entail?
Your average factory work; loading products into machines, packing, boxing, visual inspection, cleaning etc
Need people who are aware of their surroundings etc if they see an issue downstream/upstream they act on it and notify people.
Does anyone know of a way to recover files from a phone with a broken screen?
Phone still works but screen is just black
Tried connecting it to PC but I still need to unlock screen on phone and select "connect" which I can't do
Any ideas bros and hoes?
I thought it auto syncs and you don't need to unlock.. I've never had to unlock the screen
Ok C@dbury, cool!
Also, Pat's parents have a company, was just seeing which one.
Good memory. Nah at my place of work. :)
Yeh C@dbury in the "lets make shit more efficient you fkn slackers" area
Hahaha sums up my position quite nicely.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
