I'll kick your ass...
you probably will, but if someone else is paying. why not.
we should feed them to bums and watch the outcome.
on another note! i am so f**king sick of time wasters. i had one dude haggle me last night offering some stupid low amount and expect me to give him a roady worthy for that amount. then he comes and sees the car today, and say I would really like a car with a lot of space.
ITS A f**kING SILVIA
for f**kn f**k.
why the f**k waste my time you little flamin mongrel desease. f**k
lol Aaron, when i was selling my old car. This one guy said he'll come this day and time, confirmed with him again earlier that day then comes 30mins past the time no show. Contacted him and he said he's not coming..... rushed home, washed the car and even canceled my night.
The joy of time wasters!
Fk it's so annoying man. Seriously though he was after a big car, why even consider the 200 and waste my time to begin with. Slap the little f**k
Screwdriver the dream boats
Jonoe how much for your services? Can you make faded paint with lack of clearcoat look somewhat less unappealing?
More than you can afford pal.
I can do it. But it will only last 1 wash. Lol. And I'm not doing that. Too much labor for nothing.
I'll need to see the car irl to see what I can do :]
Smoke em..
Will hit you up once it's moving again.
Hottest thing I have ever eaten was a Thai jungle curry we made for staff meals at Mopho once... 40 green scud chilli's (thai chilli) per plate... It was the only time I have ever felt my stomach burning internally from chilli...
Would do again
On an unrelated note...
Snuck up on my fish last night (African cichlid tank) at like 4am... It was freaky! African Cichlids (particularly tangyanikans) are highly aggressive fish and are always fighting and playing chasey etc... They were all sleeping on the bottom in their caves... But they were actually lying on the substrate for the most part... One of them had even buried himself down inside the floor of a cave!
/csb
#fishlinesaustralia
/csb
#fishlinesaustralia
My axolotls used to dig tunnels everywhere in the tank it was rather funny. And I used to hand feed them, sometimes they would mistake my finger for food, they would bite your finger(no teeth felt like a suction cap) and would not let go.. You could drag them around the tank lol almost as if they enjoyed it..
/mycsb
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
