LOL just saw this, to clear a few things up -
Just cost me $800 for the flash tuner and $600 for the tune
No retardation of timing, no pulley, no exhaust, no e85, no intercooler, no injectors, no aftermarket boost controllers or anything like that just a tune and K&N air filter replacement. Standard the blower bleeds out boost after hitting 4 PSI on the tune (for the GS) much like a turbo wastegate, the tune basically stops that from happening, increased to 9PSI and made another 120rwkw on a very low reading dyno (made 250 stock compared to 286 on chasers dyno) would see over 400 on some other dynos for sure..
Duno why people are so surprised there's more cars out there than skylines, and before haters start hating I've owned 3 of them before this.. I mean it's no GTR through the corners but definitely better than I thought it would be through the hills. It's a daily to / from work car and I love it. End of the day I was never tracking my GTR and just getting cop hassles
Here's a video to show what a tune does
I know what some guys here are saying that's it's a charged 5 liter etc. I still think that's a very high amount of power for basically a stock car, given mods. I'm no ford fan by any means far from it but I give credit where it's due. Know a guy who's dad ownes a 5.5 liter charged e55 Amg with a tune or chip and it didn't get anywhere near the gains like this. Iv read a about people charging v8's and it wasn't as simple as bolt on, tune and result in close to 400kw. I think it's bloody impressive, good on you mate.
This...
It's an awesome amount of power and a very cheap increase, but it's very conservative from factory. By blown 5 litre standards 370rwkw isn't huge. And comparing them to modifying engines with half the displacement is as retarded as Aaron's timeshare insurance idea.
Hahaha it wasn't my idea and I didn't compare u fag
haha cheers mate, its definitely fun !! :D
And you are comparing a $40-50k car with a $15-20k car.
Which one is going to loose you the least money when you go to sell?!?! Sure the blue oval isn't going to command anything more than $15k in 3 years time.
Pointless comparison
Rain is good for a waxed car...it washes most dirt off and doesn't stick to the car itself, attracting dust and then drying to make it dirtier...ala an unwaxed car.
1. Paint protection
2. Stays cleaner for longer
3. Easier to wash
"Long story short, i sold my EG with rwc. now the buyer calls me 5 days after saying the wipers are broken and not his fault etc, that i sold the car to him in an unroadworthy condition... the workshop passed rwc so clearly it was working then. and it was working as i drove the car for 2 weeks AFTER getting rwc up until buyer picked up the car
what can i do about this? its f*kn bullshit. do i have to prove it was working when he picked up the car and that it broke in his possession?""
Doesn't need to be transferred either, as long as the Vic roads transfer papers are signed, it doesn't matter, if the car hasn't been transferred after two weeks the seller can actually go in and transfer it themselves
Tell the ma'f**ka to have a coke and a smile and shut the f**k up
next time the ma'f**ka calls tell him I said suck my dick
I thought you had an EK?
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
