aint that the truth.
I dated one (girl, not the grandma) and grandma was disapproving to say the least. I had a beard (never earns brownie points with the elderly) and trying to describe what I did for a living in cantonese was a challenge apparently.
just say "ngor hou dor qin" that should fix the disapproval part.
