what he said go to any exh shop they will ahve some flanges and a piece of pipe, sorted.
do remember if epa catch you 10K fine tho ;)
only use it for the track if youre worried.
putting a cat in for street use it only going to make it rich.. and only by a small margin if that.
Going to order a 3inch, high flow 5inch body venom cat. But its about a 4 week wait.
Just thought of using something temporarily for the dyno.
MIght just ask trent to tune it with the exhaust dropped from the cat onwards
Don't they have mobile EPA stations these days that randomly pop up these days?
Not sure if its worth the $10k fine..
like any cat that 15 years old is fully functional anyhow.
but the idea of the straight pipe in a cat body is the best one. know a few who have done it looks perfect and great performance.
I thought you only got that if you ran rich,
no cat and it tuned correctly I've seen many with no soot.
Yep, you get soot when you're basically pissing fuel all over.
i have this... it even sounds like a cat when you tap it cost technically it's not hollow
this
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
