what he said go to any exh shop they will ahve some flanges and a piece of pipe, sorted.
do remember if epa catch you 10K fine tho ;)
only use it for the track if youre worried.
putting a cat in for street use it only going to make it rich.. and only by a small margin if that.
Going to order a 3inch, high flow 5inch body venom cat. But its about a 4 week wait.
Just thought of using something temporarily for the dyno.
MIght just ask trent to tune it with the exhaust dropped from the cat onwards
Don't they have mobile EPA stations these days that randomly pop up these days?
Not sure if its worth the $10k fine..
like any cat that 15 years old is fully functional anyhow.
but the idea of the straight pipe in a cat body is the best one. know a few who have done it looks perfect and great performance.
I thought you only got that if you ran rich,
no cat and it tuned correctly I've seen many with no soot.
Yep, you get soot when you're basically pissing fuel all over.
i have this... it even sounds like a cat when you tap it cost technically it's not hollow
this
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
