Should be free Sunday morning if you're into getting up early
No problem, thanks man hopefully I don't run into any troubles :) all depends how wide nt05s are!
on another note, moto gp on tonight! stoners last race (on a bike at least)
Come past when you get them fitted...wanna see dat traction.
that thing is gonna be a rocket ship with NT05's
Anything wrong with an 04 fireblade?
Workshop selling one good price tempting considering just trading in ma 2fiddy for it.
(Insert death/coffin joke here)
Speak to that Frank guy on TC, he seems to know Hondas. Always says you can't go wrong with 08 onwards for the blades
Lol nt05s
See you later diff lol
haha yep should be heaps better! I was getting 4.5s to 100 with gtech and huge spin surely into the 3s now, should be good from 2nd gear rolls now tyre diameter is about 1" fatter as well (245-35s bit skinny walled imo)
Lol nt05s
Usually input shaft will go first, but yeah I wont be launching it all the time I'll just roll out then punch it :P catches up pretty quickly to people
Wont be doing burnouts on these either at 375 a pop
Manuals are the ones breaking more stuff, CVs and tail shafts, clutches usually but yeah depends how you drive - dumping clutch on slicks starts to hurt stuff
Well they can't hand out defects for phaggotry
if the phaggotry consits of more than 5 people standing around multiple cars it constitues a hoon offence... so yeh... they can
VELCOME TO MELBOURNE JA!
Al said they cant hand out defects for phaggotry, you said they can.
The point wasnt about anything else, but phaggotry.
So....
How can they give you a defect for being a hoon(Phaggotry)?
:mrt:
they see you being a phaggot, and then decide to give you a defect because of the phaggotry
so they give you a defect for whatever they feel like to make it "legit"
pretty simple ;)
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
