Its been previously tuned with Trent when I had the nistune about 2 years ago.
Ah alright, must have been a nice safe tune then :)
265rwkw, yay powwwwar :D My coilpacks died as well within 24 hours of the new power levels, not on the dyno though.
Mine's going in for a retune with a new dump and the exhaust mani leak fixed, hopefully will bring some nice results. My goal is now to beat whatever you get on thursday ;)
Lol well im hoping ~280rwkw
Trent says 300rwkw if I can hold boost at 19psi
Come at me broooo!
258rwkw on Shell 98...I'd rather this and be able to fill up anywhere than tuned on BP and restricted to that.
That said, once I get a job I'll probably do an E85 tune so there goes that advantage.
Radiohead tomorrow night :D
Im an avid Radiohead fan, but seeing them in a stadium after watching all the Live In The Basement vids... nah thnx
my housemate was at the sydney show and she filmed a bit of it. awesome lights show, but just another band in the distance in a stadium playing good music. and Thom Yorke's singing live kinda ruins it for me. love his stuff (and dance moves), i just think he gets carried away
Aaron got my fronts today they're fine - my only complaint would be that the wheel nut holes are silver from being shaved / cut out. Pretty sure most others aren't like that? maybe i can just take a bit of black paint to it or something..
Dude on a zx-10 in a helmet, short sleeve t-shirt, trackies and sneakers... I hope you fall off very soon
Caught up with a mate the other night who wrote off his friend's R6 wearing shorts and thongs. Got off very lucky but scraped up to the shit from it.
Nah even mine came back. I thought its better like that as everytime u take off/put on wheel nuts it won't leave that scratch mark.
We doing Sunday? Or u gonna wait till next week?
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
