You know even in primary school I had a feeling you were headed for IT :)
But fark if I didn't spend every day of grade 5 using Web Wombat (Google didn't exist) to search for Garfield comic strips myself...
Garfield books were hot property at the school libraries. Had to reserve that shit.
Why you reading so many build threads?
Got some build ideas coming up? :D
Not quite, they just depressed me when I realised how poor I am... trying to save for a house but its not working too well ;)
:woot: fo sure
loved the comics as a kid but didnt really understand the concept of being depressed let alone, being depressed and owning a cat. But now I love Garfield minus Garfield.
Your knives are no match for my 1 inch nails that I used to grow on my pinky fingers in my younger days.
Anyone else going bike expo this weekend? Better be worth the $20
happy to take the pepsi challange any time :P
too hot or too cold?
Thats what I was thinking, Sri Lanka has an average temperature of almost 30c doesn't it?
Was probably complaining it was too dry since we don't get that crazy humidity...
lol yeh, sri lankas way too hot, they come here and usually think its freezing..
and dry heat, is always better then humid heat
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
