Thought I'd give my filthy car ( :( ) a wash today... then checked the weather to see it's raining soon... so much ceebs nao. Sigh, standard melb.
I normally get lazy, wait till it rains and gets it wet... give it a quick going over with a microfiber towel... then go back inside and let the rain rinse it clean.
Trolling sports bikes?
My mates DRZ barely pulled away from my 250 Ninja....Good luck trolling a 600+ super sport
Off the line I mean, I duno maybe its the rider :P but yeah some of the more powerful / light weight motards could get off the line pretty well I reckon anything off a roll would get owned though.. still it's all about the corners and being able to go anywhere. Wana do phillip island on a tard lol
Yeah looks good...exhaust already done saves u a bit too
Getting my last two wisdom teeth out tomorrow after work..... these two special ones decided to be cool and grew horizontally.
Not sure which hurts more, the pain of taking them out or the pain of my wallet.
:domokun:
:domokun:
The answer is both...
garage ftw yo.
and on another note, its f**king hard to get filter paper in melb... none of the scientific supplies do over the counter sales, its stupid.
what do you need to filter? how fine do you need?
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
