just a note to anyone that is planning on having kids, or has kids....
angelcare AC1100
HOLY f**kING SHITBALLS this is one of the best products ever to be released
Tried gettin those extra couple inches ey?
jks brah
Well according to the Australian Federal Police, who locked my computer for looking at child pornography, I had to pay a fine of $100AUD within 48 hours to unlock my computer. If I chose not to pay within 48 hours, I would face criminal action.
Or I could restart in safe mode, delete the virus and reboot.
ROFL!
with any luck the people that fall for that are turned in to the cops or at least extorted for everything they own
Hahaha mad virus
Like the cunt from Aus post that 'delivered' my package today
Marked as delivered, not actually delivered.
f**king useless f**ks
My guy likes to leave the "sorry we missed you card" without actually knocking on the door to see if someone's home.
Even that would've been better than marking it as delivered when it's not....Now I have to waste my time dealing with these f**k wits tomorrow
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
