Might drive through it for a laugh
you do realise that even if your car is stock they can defect / EPA you and it is YOUR responsibility to pay the fines and pay to have it cleared right?
fail laws are fail :/
http://actionshotcam.../news-and-blog/
$50 from Kmart.... anyone gain to be the guinea pig and try it out???
rob drydrek on the packaging is EASILY enough reason not to buy
lol was in jess' rx8 today...
and lol rob drydick is a dickead
just buy them from a fishmonger and learn to open them yourself fool
taste 11ty times better and guaranteed fresh (alive) - not to mention cheaper
opening them isn't that hard, it takes practise to get really fast and some can give a little trouble to the uninitiated.
At the buller cruise a few years ago i took up around 6 dozen live ones and taught a few of the guys how to shuck them... i remember basti getting it pretty fast
yeah i remember. all in the wrist. just like shanking someone :ph34r:
That's a bit racist
I'm waiting for GoPro Yellow edition
you might need to invest in a wide angle lens if you get the yellow. just saying
back from horsham / bendigo today..
2nd ride on new bike, had some stretch hummer limo pull up near me at lights and chicks opened the window waving and saying hi blowing me kisses, chatting etc, I played along waved and blew one back from the helmet lmao. sport bike = female magnet? pretty sure that never happened on the tard'
Edited by UNR33L
I'm guessing you didn't open the visor otherwise they would of sped off ey Leigh.
Got her number?
If not, the answer is no.
Yeah, not that it would make any difference had the clear visor on anyway
Got her number?
Yeah man, I got my pen and wrote it on my arm
Forked pickups for my rear stand
Nah I meant what did you order from Misty's that let you down?
I recommend Langham, haven't been there in a while but it's never let me down for buffet food.
2nd ride on new bike, had some stretch hummer limo pull up near me at lights and chicks opened the window waving and saying hi blowing me kisses, chatting etc, I played along waved and blew one back from the helmet lmao. Lee = female magnet? pretty sure that never happened on the tard'
fyp
Just a once off I think
Else I'm gettin me a sports bike
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
