Full licensed from today! and now I plan to never return to victoads for 10 years.
can finally drive my own car :P part of the first batch of Red-P platers
Licence renewals can be done at Auspost now
and jonoe, mine ARE HID's, does it piss you off yet? and sif you can talk with your fkn reverse light lol
Troi oi thang den nay, tao xinh loi.
I meant top bloke HID kits in reflector housings not made for it. lol. Like them civic ricers out there.
Mah reverse light aint even on for more than 1 minute a day. lol.
you can also just use Bpay. I needed to change address and get a new photo, better to do in 1-hit. did a 10 year renewal, exciting stuff
new photos are done at auspost now too
lol, let me translate this for you Aaron. I'm sure you'll appreciate me hahaha
'oh ffs this black kid, I'm f'*ing sorry.'
Well something along those lines.....
You're a top bloke hid kit in reflectors housings
BAHAHHAHAHAHA
Ling ling, you forgot yo bling bling
Poor stu nick, he lives up the road from us now.
jap plates?
What in Thomo?
Nah USA plates
they are the USA ones....
not sure if like
look crap cause too much white
my lights are on during the day if its raining, im in a tunnel, or if the sun is setting behind me. safety thing. but i see no issue with people driving with their lights on. dont tell me it distracts you because they aren't strobes. it just makes you notice the car in question. which is a good thing.
re foglights; unless the owner has them adjusted wrongly, fogs are supposed to spread light low and wide. so they wont be blinding anyone at night. i never understood the issue people have with them
this
However running lights during the day makes no difference, infact it's been said that it causes less accidents due to the reflection of the light from oncoming cars
NT05s pretty grippy!!
MOAR LOW!!!!
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
