f*k i'm getting better at parking close to poles aye. I have to park next to a pole. And when I do, if i drive straight, mirror will just scrape the pole. Haha. Too many careless kids and people who slam doors.
I park next to a pole nearly every time. Only had one instance where I wasn't paying enough attention and the wheel arches on the Cube stick out a fair way from the body. Lucky I had the flares.
Mine were genuine too..
And birds it does no negative harm to have heat range 7's
Not harm, but takes longer for the spark plugs to reach optimal running temperature...when you're driving a daily on short trips it makes a difference. Always go as hot as you can without overheating - just like injectors, going as small as you can without running too much duty cycle.
Essentially, I could park our straight piped, externally gated S15 track car outside Knox police station...that short, fat asshole can write a Tom Clancy novel of defects for it...and then proceed to shove the whole notebook up his own ass using his tears as lubricant.
Cars have been defected on Trader Plates. So yeah, you kinda couldn't :P
I ran 7's on my SR20. Wasn't the greatest idea for a car being moved short distances occasionally. Would foul a set beyond use in 1000km's.
i was happy to sit on the limiter on a 40c day at DECA with a trent tune and never managed to get the light on....
jus sayin ;)
Btw I see you may have found 'da 1' e7 pending a check over ;)
:ninja: :ninja: :ninja:
Noice.
Edited by kaitoukid
If his name isn't Sven or Hans, you're being ripped off.
haha probably is I've just never asked :P
They are apparently well audi / vw / BMW
Hmm, still not sure man. I go to VolksHome in Thomastown because it's close to me
holy jeebize id love one but i dont think i could handle a bear haha
Nah those are big males, our female is much smaller
Dog or bear?
Nick would say Dog but its clearly a bear/beast id love to have this bad boy guarding the GTR but the fact that there bigger then me worries me
Yeah dog, although they do have a really strange smell about them that isn't dog at all
i've got a cat. feed, and ignore.
I prefer cats, I wasn't a big fan of dogs until we got Mechka though. She is the best with who know her
That's why I recommend 6s, particularly if you have a conservative/rich tune. Stock engines run 5s okay...no reason anything this side of 300rwkw can't deal with 6s for daily duties with a thrashing here and there.
Noice.
reading evolutionoz forums eh?
yeah, everything set to go as long as the compression holds up and there is no rust / structural damage
Fair point. I had to run em on the 200, I found at 270 with a four banger, 6 was just too warm
Ooo00000ooo got a link u care to pm me with?
jus sayin ;)
Every car is different :)
Just going from a PFC to a PFC-Pro with identical tune, my knock went up by 15 - wasn't a problem with the tune, just the way the ECU was interpreting the signal, so it would hummmm along at 35 and it was totally fine (where previous it'd never go above 20).
His knock sensor could be picking up a little more noise than yours did. Either way 65 knock isn't great, but it's still not bad. Anything over 35-70 usually just means there is 1-2 cells that need attention. Misfiring will also cause the knock sensor to go nuts as well, same as hitting limiters etc.
Odi - wideband won't show you much either as by the time it's leaned off to a point that you'll notice, you've already done the damage (no-one stares @ a gauge when fully up it). Much the same as oil pressure dropping when @ 7000rpm, buy the time you notice/light comes on, the motor is f**ked anyway unless you are setting the ECU up to shut the car down in such a situation via a trigger/value/aux input, which a PFC doesn't have.
I'd suggest having the fuel pressure checked, possible the walbro is faltering now and again, I had one give issues like that 6-7 years ago. However with the misfire could just be a case of a loom/grounding issue. Even voltage supply, so not the coilpacks themselves either. Could also be the CAS playing up intermittently, they have a habit of doing that when they are letting go (you can get another 6-12 months out of them sometimes before they die and the car just wont turn on).
Nissan electricals are a headache :(
you know it :thumbsup:
haha exciting stuff. same as aaron... pm me if links available if you will hehe :P
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
