Ferken...
Still need to throw the decat on, see if my Bosch 040 still works so I can swap it over on the day if required, hook up the oil cooler...
There's not enough time in each day! :P
yeah I will prob be doing a oil and filter change at the track, unless I get some spare time fri night.
that said I will also prob only do 1 session or so b4 I give up and just do passenger laps
also will probably do 1 session and just jump in with others..
standard brake lines wont last more than 5 laps i dont think..
This weather better pull its head in or Saturday may be interesting
Do you even enter brah?
Usually only 3 flying laps each session with the Wrx club, She'll be right
In saying that I'm booked all day giving people passenger laps so won't be going 100%
i plan on getting there early to get a garage ... if its 28 degree's, i sure as shit dont want to be standing outside.
Book now if you want a garage
why does it matter what colour they are?
its just going to get covered in brake dust and dirt and go black grey brown anyway.. brake lines are there to help you stop, not for a wank factor...
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
