I've found they do, then say "nah mate too hard"
In other news, engine exploded making me rather sad. That said, had car for 2 consecutive months over 4 year period. Best record yet!
Unaware unless its a change of username
What car you got and what happened?
Everything. It is nothing but a story of pain. I am that guy people talk about when "it could be worse" :P
Edit: Wasn't specifically talking about Racepace - Though I did email them about 2 years ago and got a "nah mate too hard" response to fixing my r34 :P. Do not blame them however!
Edited by Kinkstaah
Everything. It is nothing but a story of pain. I am that guy people talk about when "it could be worse" :P Edit: Wasn't specifically talking about Racepace - Though I did email them about 2 years ago and got a "nah mate too hard" response to fixing my r34 :P. Do not blame them however!
yours the DE+T yeah?
initially, until that got taken out for a neo
then that neo got exploded (before I got it)
rebuilt as a RB29 stroker, which was laggier than a RB25 and has also since exploded on the weekend (after about a month)
about a year between each of those sentences
fun times!
