Yeh the engine is, everything else seems to fight over what wants to v the weakest link.
But in my case the engine decided to fight as well, spun an awesome bearing
Put it this way, I sold with without an engine.
$10 says you sold it cos it needed an oil change
From this:
To this:
Notbad.jpg. Feels a lot nice to use. Is a bit smaller too so helps with my long lock to lock when parking.
SRS light is on though, cause i turned it on without the airbag to see if it was straight. Now to find out how to reset the srs ecu...
I would assume same as Skyline. Remove earth from battery, pump brake for a little bit so all residual power gets used up, then connect it all up again.
http://www.youtube.com/watch?v=FpWwvWgQ0o4
Came across this board when I was browsing through youtube. Get's a bit repetitive after a while but gave me a couple of laughs. Watch if you're board and have nothing better to do with your life....*sigh*
well if you spun a bearing...you would ahve to change the oil after that..taking the engine out to change oil was probally a little much, and being too lazy to put engine back in as it fell down the back of the couch...
so yeah oil change it is ;)
front lower ball joints cannot be replaced separately, the whole control arm has to be changed. uppers too 500$/control arm?? i dont think so.
Saw the up to the Mario Kart bit and was like wth.... as if they would use Mario Kart and air it until i read the description... lol
Aaron!!!
I got my GoPro3 Aaron edition today! She's such a black beauty!
Know anywhere to buy the suction and pole mounts for cheap?
keep the standard kit on the sedan steve, some 10+15s at the rear and slam it.
i test drove a 6 speed na supra for a mate, was reasonably quick for what it is, but the thing i fell in love with was the gearbox!
Aaron!!!
turn the tables on aaron and steal his ones, bet that nigga wont expect a white boy stealin his shittttt
Dow shift is Asian, Teds usually stocks them, as with Harvey Norman, but I got mine off the site and combined the shipping
And make sure you update it before using it, otherwise it locks and its a pain to reset
    • The real question is, on some of those wild roads they call highways, how many times did a farmer in an old ute from the early 2000s blaze past you over double lines?   Tassie is a wild and really cool place, and after doing a work related road trip there January of 24, I understand why Targa Tasmania is ran there, and is so tough to do well at! We had a brand new Camry Hybrid that handled quite nicely, and thankfully weren't in an old car, because cresting some of those hills in a 100kmh zone for it to suddenly be like "surprise f**kers, this is a recommended 30kmh hard right turn" wouldn't be pretty. We weren't racing the Camry around, but we weren't slouching in the bends either. But my lord those old farmers know their old clapped out utes, and those roads, as they were absolutely hammering it!   You're also super lucky to make it up to Mt Wellingtong this time of year. It's often road closed with snow/ice! Also, I hope you hit up Salamander Road in Hobart for some insanely good food (I highly recommend the dimly lit Irish pub for a Guiness Pie, or even the bangers and mash!!!)   How long did the Ferry take to get across? I want to do a road trip of Tas on my own time, but I get horrifically sea sick, and I don't want me on the Ferry, just the car 😛
    • So far so good, about 30km on it so far and nothing out of sorts yet thankfully
    • Look at @Kinkstaah's thread on the issue.
    • Hmm not really, I'd say its race car life or modified car life when you make 3 or 4 times the power Nissan designed the car for lol.
    • I'll let others with more breakage chime in, but I can't think of anyone who had a problem with the standard centre plate before they had a problem with the standard gears - the plate generally just gets replaced for safety when the gearset is upgraded. As for the gearsets, its not like they are OK at 600Nm and break at 601. Their longevity is a combination of how much torque you are making and how gentle you are on shifts (or not).
