So today was the first day my cars temperature went passed half way and almost at the H marker.
Should i be worried?
Cause its sitting in the garage now making gurgling sounds n shit and ive never had a car that heated up that much.
Yes you should be worried. Stock gauge only hits H when something is very wrong. Check your cooling system.
there has been a bit of this going on for a while already. parts suppliers get ready to close doors, car manufacturers cant complete cars without specific part(s), so they throw enough money at it (making a loss) to keep the production line running until they find a new source for the same/similar parts.
Some of the decline of the Aus car market i think is still due to the slow and pain death of the manufacturing industry, not entirely on price and market domination
Dat awkward feel when your job is in manufacturing industry :/
+ 1
I'm going to say that your radiator is gone
Same thing has happened to me.
+ 1
Careful Steve, Tony's car is now a write off... Learn from his mistakes before it's too late. Check your coolant and make sure that you've got pressure... Could still be something simple like your radiator cap not holding enough pressure.
Lol don't scare him
My car was a write off for different reasons :P
have you checked your coolant?
Im going to guess that you need to top up the coolant in your radiator
It never hit the H, it went to the notch before when i was stopped. Mate told me to check my water pump =\
remove drain plug and turn car on.... if water is pumped out (as opposed to drained by gravity) your water pump should be fine
you'd be surprised how much of an effect a busted rad cap can have.
Lol don't scare him
Car had a minor done last week. It was when the car stopped on the freeway ( trafic ) the heat would rise, but once i started rolling (60 km/h+) the needle would drop. the part that concerned me the most was when i got it home and shut it down the water bubbling sounds it was making.
Suits best show ever waiting or season 3 bad season 2 was epic makes me wanna be a lawyer every chck is smokin! That and they seemingly do no work and make millions.
That's reality right ?
Yeah Harvey Spectre is baws
New episode is out on 17th
Pepper your angus
You're kidding right...just sending the suit back over takes a month or two.
Last time it was about $550 for a full suit + two tailored shirts.
Thats pretty pricy
I'm paying around 400 for mine with 5 shirts, Tailor in HK
last one was from thailand, quality was shit.
but yeah I went from hating suits to loving them jsut from one tailored job.
when something fits perfect you love wearing it,
oh yeah and cufflinks do rock.
mmm carbon cufflinks
The hot part is...last two girls I hooked up with were lawyers, both pretty cute...there was a third that I didn't get with. Saw a hot lawyer in the paper the other day too. Envy for Ric's job!
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
